select particular data
Mike i am haviing one doubt.....
See i am having one Array of cluster ....
The cluster inside the array has two ring and one numeric indicators
Now i  want to search a string in that array which is in the form of ring in side the array.How to search and took the index values..
Message 11 of 17
(1,124 Views)
Hi Karthikeyan,
You can unbundle the cluster elements by their names and take out the Array of Strings of the Ring control using its Strings[] property, to search for a particular String of your choice.
- Partha ( CLD until Oct 2027 🙂 )
Message 12 of 17
(1,118 Views)
Hii i donot know how to do?
i have attached a vi you explain me in detail..
Message 13 of 17
(1,109 Views)
Try the attached VI. Code is only this much(less). Smiley Wink
By the way your first 'Ring' is actually an Enum. Smiley Happy
Message 14 of 17
(1,100 Views)
Thank you very much for ur kind information.....
Message 15 of 17
(1,098 Views)
Doeas it solve your problem?
Message 16 of 17
(1,096 Views)
Yaa it solves my problem.....Thankyou once again
Message 17 of 17
(1,093 Views)
