security system solution
I posted a solution a few days ago to the example CLD question "security system". Thanks everyone for giving me your comments.  NI should let people cash in kudos for upgrades!
Based on comments I updated and fixed a few things.  Attached below are three versions of my solution:
Alarm0 - the original post
AlarmI - a better version
AlarmII - a "better" version using an event structure.
Looking for more feedback + answers to the following:
Aside from the possibility of "false triggers" is the event structure in "alarm II" preferable and why?
Is there too much processing going on inside the visible event structure frame?
I only have two event frames, one for "pushed one of the buttons" and the other which stops the program.  Should there be a timeout frame?
Should I be doing something different with propagating the error clusters?
Is there a better or cleaner way to build the security file - concatonate looks messy.
(2,862 Views)
I someimes use the Build Text Express VI. It's the only Express VI I like. Another option is the format to text Vi. You can grow it to several inputs. The format specifier for text is %s. So it would be %s\t%s\t%d\t%s\r\n with the '\'-display on.
No timeout frame. But place the stop button inside the coresponding frame. And also catch the Panel Close? Filter Event.
Yes. I would trap the errors in an error case around the event loop. Furthermore have the error cluster in a shift register, placed somewhere near the bottom of the while loop. I also dislike the write to file Vi, because it doesn't give you the error at all. At least place a general error handler at the end of the error wire.
Felix
(2,825 Views)
