search
Hi
I am sorry for such simple question but i didnt foud any clue. (I am Beginner🙂
I want to put function in Diagram Block. This function should be in "Control Design and Simulation" group but there I dont have any function
When I use Search from function windows then I see this what I want
Look at the attachments screenings.
How to make all function visible in Function windows without searching ?
Could anyone explain why that functions are not visible ?
Best Regards
Mt
(2,446 Views)
Which version and development system of LabVIEW are you using?  The Base package doesn't included Control Design and Simulation
https://www.ni.com/en/shop/labview/select-edition.html
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
(2,425 Views)
Dear Mt!
As the previous post had said, Control Design and Simulation is a separate module available for LabVIEW. Here you find more information about this addon.
Let me share a few tricks how you can find where a certain VI is located in the Functions Palette. If you right-click a certain VI it will offer you the palette the VI is located in. This is very useful if you're placing several VIs at once from the same palette. If this does not help, for example the VI is deeply nested, you can just open up the help file for the function by clickind "Detailed help" on the context help window. The help for functions is structured exactly the same as the functions themselves, so just check the tree stucture. for example, the Simulate signal VI is located in Signal Processing >> Waveform Generation:
Hope this helps.
Kind regards:
Andras Valko
NI Hungary
Andrew Valko
National Instruments Hungary
(2,395 Views)
