search value
Hi!
I'm new with LabView, so my question is probably an easy one...
I made a VI which reads files, og replaces some values. In these files there is a numeric value in the first line. I figured out how to get the first line by using Pick line, but I only need the first numeric value. Can I set any parameters or should I use another function?¿
Best regards
Klaus Christensen
(2,620 Views)
Hi Klaus,
Try using the match pattern function on the strings palette. Wire [0 - 9] to the regular expression terminal to return numeric values. Use in a loop with a shift register to enable searches beyond the first numeric instance.
Hope this helps,
Nick
(2,620 Views)
