search string
I have get the attached file details from command prompt.
I would like to know, is there any method can get the mac address string only? Which is "00-04-A3-12-32-25" and filter out the others detail.
Thanks.
Message 1 of 10
(5,618 Views)
Regex to the rescue.
Message 2 of 10
(5,607 Views)
Between, my labview version is 8.5.1. Thanks
Message 3 of 10
(5,602 Views)
Accepted by topic author TanTan
You can just paste this regex into the constant for Match Regular Expression
([[:xdigit:]]{2}-){5}[[:xdigit:]]{2}
8.5 vi attached
Message 4 of 10
(5,597 Views)
Oh, thank you. My problem is solved.
Between, may i know where can i get the definition for all these regular expression? ([[:xdigit:]]{2}-){5}[[:xdigit:]]{2}
Thanks.
Message 5 of 10
(5,589 Views)
I always refer to this page:  www.pcre.org
In this case: ([[:xdigit:]]{2}-){5}[[:xdigit:]]{2} translates to:
Look for 2 hex digits followed by -, all repeated 5 times followed by two more hex digits.
Message 6 of 10
(5,581 Views)
Hi Darin,
Thanks for your information and the solution.
Have a nice day.
Message 7 of 10
(5,577 Views)
I have one more step to do. If I would like to filter out the '-' in between the number from attached vi. How can i do it?
Example:
To: 0004A3123225
Appreciate your feedback.
Thanks.
Message 8 of 10
(5,488 Views)
Use Search and Replace on the Mac address string, search for '-' and leave the replace string blank. Be sure to set Replace All to true.
Message 9 of 10
(5,468 Views)
Hi Darin,
Yeah this is exactly the solution. I have solved my problem.
Thanks.
Message 10 of 10
(5,463 Views)
