search file
Hi all :
i want to bulid application that search file in my computer , can i do this in labview
thanks
(3,421 Views)
Hi elyan,
yes. Smiley Very Happy
How to do?
In the file palette (LV8+) you find a function to list directory's contents, sorted by files and sub-folders. Compare the resulting "files"-array with your filename (case-insensitive...) to look for your file... Use the "sub-folders" output to enable recursive search. Or use the built-in recursive search feature...
Or wait for ~1 hour, than I can attach an example Smiley Wink
Message Edited by GerdW on 03-19-2008 04:33 PM
(3,417 Views)
Hi :
I will wait !!! 🙂
thank you very much
(3,414 Views)
Hi :
this file exsist some where in my computer , i want onlyt to type the file name .. then the application tell me where is it found , and if it found or not
thanks
(3,412 Views)
Open the VI "Recursive File List" that's part of the Librarian Manager. The default location for this is "C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\Utility\libraryn.llb". This will recursively list all files from a starting location. Then, just search the All Files in Dir output array for your file. You will need to strip the path for each array element, but that's trivial.
Note: The recursive file listing will be slow if you tell it to search your entire hard disk.
(3,394 Views)
