search and replace pattern (string) not -1 when not found
Hey,
when using the 'search and replace pattern' for string with input string "0" searching for ".", past offset output returns 1 (and not -1).
(3,056 Views)
Hi kd,
it always helps to provide an example VI to demonstrate the problem:
So what's the problem?
Btw. as there is no "search and replace pattern" I took SearchAndReplaceString instead…
(3,054 Views)
Hey Gerd,
I assume Your example is not from NXG environment, but lv2017 or earlier.
I have attached a snapshot of my screen now.
thx & regards,
Koen.
(3,044 Views)
Accepted by topic author kdCMC
I'm going to take a guess that you're using Match Pattern and passed in "." instead of "\.".
"." is a special character for regex matching so it needs to be escaped.
(3,043 Views)
