scrol bars; window range
Hey there,
Is there a way to limit the range of a window, when using scrol bars?
When I place an object on the frontpanel close to the border of the window LabVIEW automatically adds a little extra space to the window. That's fine as long  as I use the scol bars to navigate inside the window. But using the mouse wheel you can scol till infinty and further. So is there a way to define solid window borders?
(2,327 Views)
Hi BigBadWolf,
you can check the property "origin". You can also write it, if you want.
Hope it helps.
Mike
(2,324 Views)
