screen lock tab control
Hi!
I have almost the same problem as this guy:
but my problem is that I don't have a solve. I have a tab control with ontly two pages. I you press a button on the first page, the tab control switches to the second page. Before moving to the second page, it executes a subvi, which has nothing to do with it....., but maybe useful information...
After that the screen freezes......the problem is that i need to inoput some data on the second screen as well....
anyone knows a solve?
(by the way, my system configuration is Pentium 4, 2. Ghz, 1 gig RAM, so I don't expect it is in there...)
(3,068 Views)
Hi Btw...,
it would be better to see your code, so I can only guess:
You propably use an event structure to detect the button press and to switch to the next page of your tab control. In this event you start your subvi. Now the event structure waits until the subvi has finished - and so freezes your main vi.  To avoid this: switch off the setting 'Lock panel until...' (found by right-clicking the event structure)!
(3,058 Views)
thanks a lot! I think that was the problem. I didn't test it yet, but I didn't see that checkbox either.
(3,054 Views)
