scc question.
what happens when you retrieve a group of labeled files. Where are they put? and how do you get the latest version of the files to appear in the dialogue box again?
Oh, by the way this is the builty in SCC
(2,702 Views)
They are loaded in your local work directory so make sure that your latest changes are checked-in if indeed you do not want to overwrite them.
To retrieve the latest version, use the Retrieve Files... menu and auto-select changed files. Files that are different from the server (latest) version will be retrieved.
To retrieve a group of labeled files, it might be safer to temporarly change the local work directory.
LabVIEW, C'est LabVIEW
(2,702 Views)
