scc 2345
I want to generate a signal with a AO Generate Waveform, but I have the scc 2345 module, and I don´t have a conector (scc socket), and I want to know what is the terminal that I must wire....
(2,735 Views)
If i understand well your question, you will need a scc-AO10 and you have to plung your wire at de pin 1,the ground, and the other one in the pin 2 or 3.
I hope it is going to help you !!
(2,734 Views)
