scan from string
I want to change some strings such as:
a
ab
abc
to enum type, but can't succeed, why?
I found that scan from string can transfer some strings to enum control, or constant, indicator?
Feeling confused.
Thanks.
Message 1 of 17
(6,341 Views)
Hi ZHH,
Please post your code and we can show you where you went wrong. Consider posting a LabVIEW snippet or upload for an older version (Like LV 2012) so that more people can see it.
Message 2 of 17
(6,326 Views)
Hi Gregoryj
Problem just solved, it is the input type match…
Thanks for your reply.
Message 3 of 17
(6,309 Views)
Hi GregoryJ
Sorry, I don't know why it seemed solved, but again not working....
Message 4 of 17
(6,287 Views)
Hi ZHH,
The VI is from LV 2016, please attach for an earlier version like LV 2012.
Message 5 of 17
(6,278 Views)
I installed labview 2016, any difference between 2016 and 2012?
Message 6 of 17
(6,274 Views)
No, but I don't have the most recent version, so I cannot view your VI. If you save for a previous version and select 2012 I will be able to view it.
Message 7 of 17
(6,271 Views)
Hi ZHH,
Yes!
In LV2016 you can open VIs from older LV versions (like LV2012) - but in LV2012 you cannot open VIs from more recent LV versions like LV2016!
(The most prominent change in LV2016 were the new channel wires! Other versions "just" changed icons… :D)
When people ask for uploading your VI in an older LV version you should do so (Edit menu -> Save for previous)!
Message 8 of 17
(6,266 Views)
I see, thanks.
Message 9 of 17
(6,264 Views)
I saved it as of 2012, does it works now?Thanks.
Message 10 of 17
(6,259 Views)
