scan from string
Hi myadav,
the error message is quite clear!
What we don't know is the content of the string to be parsed and the format used to parse it. Mind to attach relevant VI and data?
ScanFromString has an error output. You can use it to react on parsing errors in your VI - but apparently you didn't do this so far…
Message 11 of 17
(1,984 Views)
Hi Gerdw,
Please find the subvi and input value when i got no error and when i got error.
Message 12 of 17
(1,967 Views)
Hi myadav,
so you wonder, why you get an error when trying to parse "T*" with a format string of "%f%s"?
Come on: use the error output of ScanFromString to catch these errors on your own!
(Or catch the upstream error where this "T*" is generated…)
Message 13 of 17
(1,961 Views)
Hi GerdW,
What is the formate of  "T*"?
From  error output I not got any useful information.
Message 14 of 17
(1,944 Views)
Hi myadav,
It's your device you're reading data from, so you should know why you receive "T*" from it!
Well, it's very useful to know that ScanFromString couldn't parse the string. You can handle that error programmatically…
Message 15 of 17
(1,927 Views)
Hi GerdW,
"T*" this indicates that target volume is achived.
So i got erroer after completion of target  volume, But my aim is after completion of target we have to move in another condition. But due to pop  error our program stuck sfter completion of target.
Please suggest me how I remove this error?
Thanks.
Message 16 of 17
(1,878 Views)
Again: use the error output to detect any problems with string parsing - this is called error handling...
Again: check your read string for T* when you want to react on that message!
Message 17 of 17
(1,871 Views)
