scan from string
Hi everybody!!
I got this string "6:1:0x0:0x3:0:1:0: 70.90:B:A:" in which all colons are to separate each data value. By using scan from string function I´m trying to separate them, but i doesn´t works fine.
The scan string is the following "%f:%f:%s:%s:%b:%b:%b:%f" but I just can remove the two first values of the string, because I got an error in arg3.
I think the function doesn´t differ the colon and it reads it as a character from data.
How can I do it??
Thanks in advance
Victor
(4,487 Views)
You have to select "Use fixed field witdh" for Arg3 & Arg4 and set it to 3.
You get this format string "%f:%f:%3s:%3s:%b:%b:%b:%f"
BJK
(4,478 Views)
Another approach which does not depend on prior knowledge of the field lengths is to put Match Pattern in a loop with colon as the search string. At the output of the loop create an array of strings with the data in them and then convert appropriately to other data types or formats. The Scan for Tokens (unsure of exact name) function might also be useful if there are multiple delimiters.
Lynn
(4,467 Views)
Hi BJK
I can´t select "Use fixed field witdh" because not always Arg3 & Arg4 will have the same lenght (the same thing happens with all the other data values), sometimes can be 0x03 and another times can be 0x200,so..how can i do it?
Thanks for answering
Victor
(4,466 Views)
Try with
%d:%d:%[^:]:%[^:]:%b:%b:%b:%f:%[^:]:%[^:]
CC
Chilly Charly    (aka CC)
(4,457 Views)
Thanks a lot chilly charly, with that string it works perfectly!!!
Victor
(4,452 Views)
