scale x and y axis in intensity plot
Hi All,
I need to plot a 2D array in intensity plot.  But I need to change the displayed x and y axis in a different scale (i.e., they are actual single 1D arrays) instead of the index numbers of my 2D array.  Any solution to this? Thanks.
(2,759 Views)
right click the plot, and select property node.  For each axis, use the property X scale >> Offset and Multiplier.  This will start the scale at Offset (instead of 0), and put a distance between the points of Multiplier (instead of 1).
Let me know if this doesn't work for you.
Joel
(2,752 Views)
Thanks Joel, it worked out very well.
(2,742 Views)
