Showing results forĀ
Search instead forĀ
Did you mean:Ā
scale to modify
hello,
I have  a graph with a scale to modify. I have an acquisition in tension so the scale is the amplitude in volts but i would like to put it in amper. Is it possible? and if yes, how could i do?
(3,100 Views)
Well, may be some basic concepts in electricity will help ? šŸ˜‰
Have tried to apply Ohm's law ? U= R.I ?
I mean, unless you know the resistance (impedance...) of the circuit in between your measurement points, there is no way to change from volts to Amperes...
Chilly Charly    (aka CC)
(3,094 Views)
You can use a property node for the graph: the relevant properties as YScale.Offset and YScale.Multiplier. They are suitable if the relation is linear.
Paolo
Paolo
(3,091 Views)
HI
Click on the scale to modify it or go to the properties of the graph. You also can use property nodes.
Kamal
NIF
(3,080 Views)
