scale object with pane and scrollbars
I'm trying to fit graph indicator with window size and I meet difficulties with scroll bars. The point is that when I hide scroll bars in vi setup and run the program, graph indicator fills all available area. But in compiled program graph indicator doesn't reach the edges of the window. At the places where scroll bars had been, two empty stripes appeares. What is the problem and how to fix it?
(3,895 Views)
Hi Err,
this sounds like a bug, you should post it to LabView R&D.
greets, Dave
Greets, Dave
(3,885 Views)
Hi Err,
I'm having some trouble replicating the issue you're describing.  Is there any way you could post the code that's giving you trouble?  Thanks.
Stephen Meserve
(3,860 Views)
Message Edited by Err on 07-09-2007 02:03 AM
Message Edited by Err on 07-09-2007 02:04 AM
(3,834 Views)
I'm sorry, I have some troubles with posting this message. There is a part of the code in previous one. This part followed by the state machine.
(3,824 Views)
Hi Err,
Is there a specific part of the code that is the culprit?  Can you narrow the behavior down to a certain property that is being changed in the code?  It would be helpful if you could post this code here, as I think I know what you mean, but I cannot seem to reproduce the same behavior.  Also, what version of LabVIEW are you using?
Brian Coalson
Software Engineer
(3,759 Views)
Hi Coal Man,
I'm using LV8.2. Unfortunately I can't post the code of this vi, because it is a part of big project  Besides, I must notice, that such behaviour of the front panel is not the rule. It apeares from time to time after some changes in code. And I still can't say what part of the code is the culprit.
(3,744 Views)
