sbrio interfacing
will u pls tell me hw to interface a pir sensor to sbrio9632 kit........is it possible?
(3,442 Views)
Accepted by topic author Ae_Cha
Do you have a specific pir sensor in mind?
If so, what signals does the sensor provide and do you need to control it somehow, or just supply power?
Christian
(3,435 Views)
Hi Vincy,
             This is a professional forum,so better avoid 'u','pls' etc:-Use complete words.
             A plea for full words
Thanks as kudos only:)
(3,433 Views)
pir sensor provides analog signal of 3.3v and dat signal is used for controlling the movement of sbrio...............
(3,400 Views)
As you might have read in the sbRIOs Manual it is capable of acquiring signals form -10V to +10V via the Analog Input.
Christian
(3,393 Views)
