sbRIO reboot
Is it possible to programmatically reset sbRIO 9606?
I have tried to use  Restart.vi but result is error. Code for error is -2147220364.
I also tried to use Reset.vi but again error. Code is -2147467263.
In FPGA there is System Reset I/O and that should reboot system but when I set input TRUE then communication is lost and never comes back. Also when I use I/O leds in ethernet connector are switch off. So something is happening but I don't know what.
Actual reset switch in sbRIO is working just right.
Labview version is 12.0f3.
(3,918 Views)
Accepted by topic author JuhoR
Hi Juho,
I use a Watchdog to reset my cRIO systems.
Create a watchdog, set it to reset the cRIO after 0.5s, "forget" to wake the watchdog within 0.5s: RESET…
(3,901 Views)
Thank you!!
With watchdog reboot works. Just have to install watchdog feature to sbRIO.
(3,889 Views)
