07-07-2011 09:35 AM
I am working on a system that will include the sb RIO 9602 as the controller. We want to monitor the temperature inside the enclosure. The RIO board has a temperature sensor that is referred to as the chassis temperature. Reading this temperature, it is clearly higher than ambient. Where is the temperature sensor and what is it measuring the temperature of?
Bruce
Solved! Go to Solution.
07-07-2011 10:08 AM
Did you convert the value of the FPGA node to get the temperature, like described here?
Christian
07-07-2011 10:12 AM
Yes, I have done the conversion and believe the reported value. I'm wondering what exactly is this the temperature of. Is the sensor in the FPGA, or somewhere else on the board?
Bruce
07-07-2011 10:29 AM
The temperature is in °C and its the U23 chip at the underside of the sbRIO.
Christian
07-07-2011 10:31 AM
Great, thanks for clearing that up for me!
07-07-2011 10:35 AM
May I ask why do you mark your answer as solution?
Christian
07-07-2011 11:58 AM
Sorry, my mistake! It should have been marked on your reply regarding U23 on the bottom of the board.
