saving table and waveform data
what i have is a table and digital waveform graph.  what i need to do is save the data and send it to a database in xml format and then when i load the data it will populate the table and graph again.  can someone give advice or an example would be ideal.  thank you.
(2,958 Views)
Well there are a number of XML functions in String->XML, which should help you convert your data to XML.
Then, are you using the database toolkit?  If so, there's plenty of help here [broken link removed], and in the forums if you search for it.
If not, try looking here for some examples Mike Porter posted about connecting without the toolkit.
(2,952 Views)
what i was doing is just converting to xml and sending the data using a tcp/ip connection but not using the toolkit.
thank you that helps
(2,946 Views)
