saving settings file
Is it possible to have LabView save the setting of a VI to a text file?
(5,018 Views)
Hi Timkd,
    what do you mean exactly? Do you want to output on a file "VI properties..." on file menu, or you just want to save values entered in Front Panel objects (strings, bools.....)?
   In the latter case, I don't know if there's a simple VI that handle this, I'd acquire values from various elements and store them in a .ini file, since you have useful ini files functions (File I/O --> configuration file VIs palette).
graziano
(5,014 Views)
Thank you graziano, I will try this.
Timkd
(4,996 Views)
Hi!
   So, your question is "How to save to a file all input data in  the front panel?", right? Smiley Happy
graziano
(4,975 Views)
Yes, it is. I did think of a crude way of doing it. I just merge the signals and save the merged signal to a measurement file and comment with the titles resulting in the attached. Do you know of any way to have Labview put the titles above its respective setting?
Timkd
(4,961 Views)
What I would do is scan for all controls on the front panel, and get their names & values.  Those would then be written to an xml file.  Very simple to implement in LV8.x using the "Flatten to XML" & "Write to XML File".  The xml file is also easy to read in a text editor, and the data can be just as easily read back from the xml file.
RayR
(4,953 Views)
Thank you for your help
(4,939 Views)
