saving front panel input variables?
Basically I need to save my front panel variables without having to retype them every time I load my VI, such as:
data rate = 20000
samples per channel= 400000
number of channels = 6
average time = 0.001
so on ...
kinda like when you open an example file from the help menu, you just run the VI without entering any variable values. I know this is probably a " save with options " deal, but I tried a lot, and doesn't seam to pertain my values when I load the VI.
help please,
Ed
(5,421 Views)
just right click on your variable, chose data, set current data as default, when ever you load you vi, the default values are there.
(5,414 Views)
well, isn't that nice ... 🙂
thanks
Ed
(5,411 Views)
You're right. This is an otion in the development environment.Go to Operate>>Make Current Values Default. That will make all the values of your front panel controls the default values.
You can also individually set each control default value by right clicking>>Data Operations>>Make Current Value Default.
I also suggest having a look at all these articles/KBs:
Default Values refs
Cyril Bouton
Active LabVIEW Developper
(5,410 Views)
Thanks again , I suppose it would be faster to set tham all at the same time.
wonderful 🙂
Ed
(5,405 Views)
Thanks!
(The first option is now changed to Edit>>Make Current Values Default)
Best,
Hossein
(3,435 Views)
Thank you ❤️
(2,156 Views)
