saving data in spreadsheet
Hello every one..
  Iam unable to find reason of problem that is the data is not saving in spreadsheet file..plese give me a solution for that...iam attaching my labview file and read file.plese save .lvm file in your       G-drive...
                                 Thank you..
(3,286 Views)
     I have checked your code its running fine. make data write location in default file. here i have attached the saved data. explain your exact proplem.
Happy to Wire
(3,232 Views)
The data saving but displacement and velocity showing zero but actually the data is presented in indicator.in excel file it is showing zero.
      Thanks for response..
(3,228 Views)
Actualy there is no problem with write to speardsheet file. its just log the data what you are feeding. check your code that is generating 0 value. place a indicator before write a data you can easily find the mistakes.
Happy to Wire
(3,223 Views)
