saving data from while loop
Is there an effective way to do this? I'm using the write to spreadsheet subVI. The application is a high speed DAQ card taking data at about 20kS/s. I'm using a producer/consumer pattern, the producer loop acquires the data and the consumer loop does some calculations and plots the data. The problem is, when I used a local variable (in the form of an array) and kept inserting data to the end of the array, my code was extremely slow. I tried using a queue, enqued the elements without dequeing and then flusing the queue when I was ready to save. The flush queue left out large chunks of data. Can I put the write to spreadsheet subVI directly into the producer or consumer loop and use append? Hmm, I will try this now, but any suggestions for better ways of doing this would be greatly appreciated.
Tim
(3,581 Views)
Hi,  putting the write to spreadsheet in the producer loop will slow things down.  The local variable slowed things down because it forced a switch to the front panel thread.  Using the queue is the way to go here.  Have you tried dequeueing one element at a time, and writing each element to spreadsheet as it comes off?  I think this would make the best use of the Producer/Consumer architecture.  You just have to be sure that your queue will not fill up, once it is full you will no longer be able to add elements to it.
(3,580 Views)
Awesome, I will give that a try. I never really thought to write to spreadsheet while taking data at the same time, I had all the data stored somewhere before writing. Is the write to spreadsheet subVI reentrant?
Thanks for the help.
(3,573 Views)
Why do you want it to be re-entrant?  Are you planning to write to multiple files in parallel?
R
(3,568 Views)
Yup, I am collecting data from two devices and would like these to go to different files.
(3,546 Views)
