saving clusters to file
Hallo,
I have a cluster like this:
a 1
b 2
c 3
I want to save it to a txt-file. Buiding an array is not possible, saving the cluster directly doesn't work properly.
Arno
(2,964 Views)
Hi Arno,
If a txt output file is required, then I believe you'll have to unbundle the cluster, convert all numbers into strings, and then use a string array to write to the file.
hope this helps,
Dan
(2,964 Views)
Arno,
You can use Flatten To XML to get a string with labels and values (Advanced
> Data Manipulation >XML). Use it's counter part to convert it back.
Wiebe.
"ASCologne" wrote in message
news:50650000000800000094E00000-1079395200000@exchange.ni.com...
> Hallo,
> a 1
> b 2
> c 3
> Arno
(2,964 Views)
