saving COM port settings (VISA Configure Serial Port settings) to an .ini file
I'd like to save user-updated COM port settings to an .ini file on exit, but it doesn't appear that the NI_LVConfig.lvlib:Write Key.vi will accept the COM port (VISA session of class instr) as a direct value input.  Is there a way to convert that class instr into something I can write into the .ini file? [LVPro2015]
Thanks!
(3,633 Views)
Accepted by topic author GiantUncleJohn
The VISA Session can go right into the Value input and it will coerce to a string.
(3,627 Views)
Thank you, crossrulz!  My polymorphic selector was set to something other than automatic or string so I was getting a type mismatch.  All good.
(3,605 Views)
