save waveform of tds3000 with time axis
I am relatively new to LabVIEW and am trying to capture a wave from a TDS3054C oscilloscope. I have installed the drivers and have successfully made a VI which displays the wavefrom on a waveform graph (VI attached). Now I want to save the waveform into an excel file which will allow me analyze it. Now the problem is, if I use the "export to spreasheet" block under Programming>Waveforms>File IO it writes it so that the time is written as time stamps. That is not how I want it. I have available with me the waveform, t0 and dt how can I generate the X-asix from it?
(3,017 Views)
Your VI does not have any Export Waveforms to Spreadsheet and you don't say how you actually want the file output to look.
(2,983 Views)
You should be able to change the waveform properties to use relative time instead.
Bill
CLD
(Mid-Level minion.)
(2,975 Views)
Basically I want to store the exact same thing that is being shown by the waveform graph the scale goes from -0.002 to 0.002 but the spreadsheet when saved it is not that way (example of what is being saved in test.xls) but I want the original x values as shown in the waveform graph which goes from -.002 to .002.
(2,966 Views)
Ugh, I see the problem you are having.  Unless someone has a better plan, I'd convert the timestamp to seconds and use the write to spreadsheet file.  There has to be a better way, though... anyone?
Bill
CLD
(Mid-Level minion.)
(2,957 Views)
Simple enough with the Write to Spreadsheet.
(2,952 Views)
