save the output files with the same of the input files
i think he askes the same question but until now does not get any reply
Message 11 of 18
(1,368 Views)
Hi Baja,
he already marked a solution among the answers he received...
Message 12 of 18
(1,367 Views)
Can anyone answer me with this mentiones above!!
Message 13 of 18
(1,365 Views)
Hi Baja,
Read all messages in this thread to find your answers...
Message 14 of 18
(1,364 Views)
He asked the question after accepting the solution, and no one answer him
I think it is wrong to don't accept the question as anew topic.
Message 15 of 18
(1,360 Views)
Hi BaJa,
I think message 8 in this thread, that I wrote and quote below, answers their (and your) question:
You can use the "Pattern" input to your List Folder call to limit the files that are returned.
In that case, "file-???.txt" or similar might work. You can use * for any number of any character, and ? for one character (any character), but the node doesn't support full regular expressions.
If the Pattern input isn't enough for you, you could try getting all of the files and then using something like Match Pattern or Match Regular Expression to see if the filename matched a more complicated pattern.
In your case, I suppose your pattern would be something like "Detector-???.txt" or similar.
GCentral
Message 16 of 18
(1,353 Views)
Hi Baja,
read message#8, it contains your answer...
Message 17 of 18
(1,351 Views)
Pattern input is ok, Now it is working
Message 18 of 18
(1,348 Views)
