save parameters in a file with a predefined extension
Hello everyone!
I've create a VI which is saving parameters listed in a table. The saved file has *.zpw extension.
It's working perfectly (please see attached VI)  but I want it to be more "professional".
I mean, I'd like to present to the user a friendlier interface ( "Tab Control" ) so that he shouldn't scroll down the table to enter the values of the parameters.
I've been thinking and trying many ideas but unsuccessfully.
I'd be grateful if somebody could give me some ideas
Best regards
Kabanga
(3,114 Views)
hello,
 things like that :
Message Edité par tinnitus le 03-13-2008 01:32 PM
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,106 Views)
Hi Tinnitus !
thanks for your answer!
It's something like that. But how could I present to the user all the other options?
The saved file should be txt file.
Thanks for your help
Best regards
Kabanga
(3,087 Views)
its a little bit tiresome but all control have to be included in the cluster: extended cluster size and put your controls.
this method not permit not save in text file, it's their a real necessity ?
it surely could be but i don't xperimeted enough, maybe adding unbundle function to cluster to make each parameters a string then a table of string
but i d'ont know how to proceed
Best regards
Sébastien
(3,075 Views)
yes, there is a necessity to save in a file that can be open with a simple text editor (though with .zpw extension).
This created file is going to be used for another application. But your idea is good and I'm trying to get something from it. Thanks!
Does anybody have another approach?
Best regards
Kabanga
(3,073 Views)
