save or clear on button press
My program collects a couple points of data on a button press using a state machine. The data are velocity measurements from multiple points along a track - I've got that part working (in the vi attached it's just random numbers so I can tinker with the code without plugging in the hardware).
Each measurement is appended to an array and added to a graph. Oon each button press the data exits the case structure and goes through a for loop with a shift register. Using this array, I am trying to implement two buttons: clear and save. Pressing clear would empty the array and the graph, while pressing save opens a dialog to save the numbers. It almost works! It saves fine, but to clear I have to press "clear" and then "measure" again.
I think my problem lies in how I'm attempting to reinitialize the main array, but after a lot of searching the forums I'm still stuck. I'm not sure if I'm almost there, or if a for loop is the wrong way to go and I need to get rid it altogether?
Thanks for any help!
(3,679 Views)
Accepted by topic author chet1
Fairly close.  You forgot that latching booleans need to be in the event case that reads them-  A chart works better than a graph and you never provided for a stop event.  The User interaction is enough to throttle the loop and the wait is not required.
No LAVA CCT here so a snippette would be unusable but I did attach the modified code (Saved to LabVIEW 2011)
"Should be" isn't "Is" -Jay
(3,671 Views)
Thanks a ton!
(3,661 Views)
Actually it's still not quite there, sorry for being hasty. Now when I press save, only the most recent measurement is saved to disk. How can I make it so every data point showing on the waveform chart can be saved?
(3,656 Views)
Just get the chart history instead of using a local variable.  You do that with a property node.  Look in the Clear case, copy that property node, change it to a read and wire it up appropriately.
(3,650 Views)
Or simply right-click the Local and Change to Property node
(3,633 Views)
