save new mat file: MATLAB
I am not able to save a new MATLAB file (ie. create a file) from LabVIEW . This is possible in MATLAB by using the command: save(filename, 'variable'). When I do this in LabVIEW for a new file, I get a message saying that the file does not exist. This does not happen in MATLAB. How do I get around this? In my program I need to create many mat files with data collected while LABVEIW is running.
I would appreciate any incite in this matter,
Ivanka
(7,511 Views)
Hi Ivanka,
If you would like to post a sample VI, I would be happy to look further into this issue!
Travis H.
LabVIEW R&D
(7,497 Views)
Here is a sub vi. Please let me know if you need more clarification. Thanks,Ivanka
(7,492 Views)
Hi Ivanka,
If you are wanting to use this data in Matlab, you might want to follow the KB linked below:
Can I Import Data from MATLAB to LabVIEW or Vice Versa?
http://digital.ni.com/public.nsf/websearch/2f8ed0f588e06be1862565a90066e9ba?OpenDocument
Hope this helps,
Travis H.
LabVIEW R&D
(7,485 Views)
Thank you,
I actually figured out my problem.
have a great day!
Ivanka
(7,478 Views)
would you mind to post your solution?
-Joe
(7,476 Views)
Sure,
Actually, I found that my problem was that I was executing the line
load (file, 'results')
when the file didn't exist! I realised that you cannot load non-existing files, but you can save to new files. So I just deleted that line and everything worked!
(7,472 Views)
