save my data acquisitons a pink noise
Hello someone could help me record level? I can not save my data acquisitons a pink noise with the VI "Write Data
(4,336 Views)
Hi G.,
help for what?
What is "record level"? What are "my data acquisitons a pink noise"? Which VI is ""Write Data"?
Mind to attach your current VI?
Mind to explain your problems?
Mind to tell us, where you are stuck?
(4,331 Views)
Hi GerdW VI I want to use is this: "write in a measurement file". My job is to generate pink noise with a speaker. The goal is that I get the signal with 5 microphones and me to do the Fourier transform for us to display frequency-base. Then I must view all excel and for that I need to record data but I can not .... Thank you for your quick response and sorry for my english ...
(4,323 Views)
Hi G.,
Ok, what have you tried so far?
Why can't you? What's the problem?
Repeat again:
What have you tried so far?
Where are you stuck?
(4,317 Views)
I try to create a file and open the file but it does not show my values.So I try to "write in a queue measurement" but I can not seem to abscissa column.
I'm stuck when it comes to the end save the data.
The spirit of joining your current VI?
Here is my current VIThank you
TANK YOU
(4,301 Views)
Hi G.,
your "Write Data…" ExpressVI isn't connected to ny data wire (aka "signals"). How do you expect data to be saved then?
Why do you copy data to the clipboard?
(4,289 Views)
