save image using write file2
I am acquiring real time images using laptop web camera.
I want to save them and read them to use in another application.
I connected the vision acquisition express to imaq write file 2.
I used imaq read file to read the written image files.
When I tried I encountered the following problem."Error -1074395989 occurred at IMAQ ReadFile
Possible reason(s):
IMAQ Vision: Unable to read data"
Thank you for your help.
(3,011 Views)
Can you show the VI you are using to save and to load the image file?
Here's a little example for how to read an image from file and display it :
Hope this helps
Epictetus
Antoine Chalons
(3,004 Views)
Thank you for your response.
Please check the vi attached.
I want the main vi modified.vi to be fixed.
(2,996 Views)
