save data
I have a waveform and string data , and I want to save both of them . It's not likely that I can save them using write to spreadsheet . And the most  important, I must be able to read and display them back to their original places . What can you recommend ?
(3,289 Views)
hi,
Just bundle them both and make acluster, then write to a file with this cluster as the datalog type
While reading, define the data log type again as the same cluster and read it back.
After reading, u can unbundle them and display them as you want
regards
Dev
(3,277 Views)
I've attached some VIs that demonstrate datalogging.
Sam R.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,260 Views)
Thank you very much , that did get me a lot closer to my goal
Herman
(3,234 Views)
