save data every day in new file
I've created an application that runs continuously. Sometimes it generates a data (string) and I want to save it in a file. All data of one day are saved in one unique file. The next day the data generates are saved in another file. Every day the application generates a new path.
I'm using open, write and close functions I/O and I'm using a subVI that when the application generates the new path close the reference and  open file with the new path. In this moment occurrs an error (Error 1 occurred at Write File in save.vi).
Also when I run the vi... why it ask me the file to save it (at the begining)  when the function have connected "open or create"?
Thank you.
vicen
LV7.1 / WinXP
(2,752 Views)
Hi vicens,
connect your path to the file path input, not to the start path input. I have tested it with LV8.5, maybe there are differences.
Mike
(2,749 Views)
Thank you, Mike,
also, I've solved the error. I needed to create another sifht register to refnum!
(2,743 Views)
