save control as image, without vi header etc
I want to save a control (xy graph) as image -
it works partly, but does save a kind of frame as well, with the vi header and footer etc -
is there an easy way to avoid this?
I am using invoke node get image, and write jpeg/bnp/...
Thanks for any help,
Stephan
(2,496 Views)
There is a Get Image Subset in the picture functions. If you know the location of your control, then maybe you can remove the image section that you need before saving.
(2,489 Views)
