save complex data
Hi ,i have complex data( a1+ib1,a2+ib2,...,an+ibn,...),and i need to save these data as .FRF or .DAT.Is better if i save those data in colunm
a1,b1,a2,b2,a3,b3,....etc.How i can save these data?Thanks
(2,814 Views)
You can just use the standard file I/O VIs. Check out the ""Write Binary File" example that ships with LabVIEW. You can just change the arary to a complex and you're done.
(2,802 Views)
