save array of clusters in tdms file
I'll let you take it from here...
Message 11 of 15
(1,579 Views)
OT: @crossrulz .. why does your snippet looks different than mine? e.g. the grey labview version and date/time
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 12 of 15
(1,565 Views)
@jwscs wrote:
@OT: @crossrulz .. why does your snippet looks different than mine? e.g. the grey labview version and date/time
I use the Code Capture Tool.  It is way better than the built in snippet maker.  You can get the CCT from the LabVIEW Tools Network via VIPM.
Message 13 of 15
(1,555 Views)
Thanks for the solution, but If i enter the values only in first row and save,then all the bottom rows take the first row value which I dont want. Is there any way to avoid it?
Message 14 of 15
(1,530 Views)
not sure what you reference/do
but if you always get the same, then either your data is the same in all array-elements, or you only work on the first array-element
Message 15 of 15
(1,509 Views)
