save a string to a file ...my file need a particular file name (time, date, etc)
hello to all,
i have to save a file with a string..,with results of a test
the file name must include time and date of my test, and has to append 2 underscore if my test failed
some idea?
Using LabVIEW 7.1
Message 1 of 14
(3,350 Views)
Checkout the examples that ship with LV, you will find one that shows how to build a filename. Also consider going through the tutorials that ship with LV.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 14
(3,344 Views)
I have one VI Check it out
Message 3 of 14
(3,338 Views)
Hi gigi,
converting your requirement word-by-word would result this:
Message 4 of 14
(3,330 Views)
ManLD i can't open your file....i use LabVIEW 7
Gerd, i think it's what i need thanks....just 2 questions...
what is time of test icon? and where i can find it?
idem for last icon (on the right)...what is?
Using LabVIEW 7.1
Message 5 of 14
(3,325 Views)
Hi gigi,
- last icon on the right = "Save to text file"
- "time of test" icon = timestamp control (to be found on numerics palette or - as usual - by right-clicking the input of the FormatTimestring function and selecting Create->Control...)
- LabVIEW7 doesn't know about (special) timestamp controls (if I remember...) so use a DBL control instead
When using such an old LabVIEW version you always should indicate that in your questions! (See my signature for suggestion on that topic...)
Message 6 of 14
(3,322 Views)
it works also without time test icon...
but i have a little problem...in this way year is 13,,,and i need 2013 😞
Using LabVIEW 7.1
Message 7 of 14
(3,314 Views)
done...just putting Y instead of y 😄
thanks all
Using LabVIEW 7.1
Message 8 of 14
(3,311 Views)
ops...another problem 😞
for months i need abbreviation of name 😞 JAN, FEB and so on 😞
Using LabVIEW 7.1
Message 9 of 14
(3,306 Views)
It is all right there in the online help: time format strings.
In this case use <%b> and optionally convert it to upper case.
Message 10 of 14
(3,301 Views)
