save a new file
Hello I realize sound effects with labview.
I would like to save the new sound which modified by the Vi but I don't konw the good function.
I will listen the sound after it was modified.
Help me please
Labview 7.0
(2,724 Views)
You've got the Snd Write Wave File in your VI. You just need to wire it up. Maybe something like the attachment below.
I also cleaned up the wiring on your diagram. It was pretty sloppy and made the program hard to read.
(2,712 Views)
I am sorry I'm a novice but this Vi doens't work. I want to save the file after it is transform.
(2,689 Views)
It's writing the modified data after the while loop stops. The only reason I put it there is that is where you had the function in your original post. If you want to write with each iteration of the while loop, put the write file inside the loop.
(2,686 Views)
