sampling time increased when arrray loop added.?
hi folks,
dont know if anyone saw my other post earlier, but once i put in a for loop into my vi, to send mean power to a excel file, the timer interval increased alot. from 2/3 seconds to 10+ seconds. ? how can i reduce this time?
thanks!
EMcN
Message 1 of 17
(3,695 Views)
Need some help here.  Can you post your code.  I am willing to look at it because sounds like something is not right.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
Message 2 of 17
(3,669 Views)
The code is in this post. I think the fundamantal problem is that the write function is inside the loop so he's taking a hit due to the file I/O. The write function should be outside the loop.
Message 3 of 17
(3,662 Views)
i tried placing the write outside the loop, but it didnt work at all, i mean no data was written.? what can i do here?
regards
Eric
Message 4 of 17
(3,653 Views)
Eric,
You code could use some comments and you may want to consult the LabVIEW Style Guide for hints on cleaning it up.  I don't think the file write has anything to do with the issue.  I do think it is caused by a serial timeout that it is not finding the termination character.  Since you have no error display you are not seeing it.  Are you initializing the instrument inside of the loop?
Try:
Set serial timeout to 20 seconds and see if it runs even slower
Enable Highlight Execution mode and watch your code run
Let me know what you find,
Matt
Matthew Fitzsimons
Message 5 of 17
(3,651 Views)
it works perfectly, i know its a bit messy. but when i move the write blocks outside the loop, the vi works as per usual ,but no data actually gets written.
how do you set the serial time out?
regards
Eric
Message 6 of 17
(3,646 Views)
When you moved the write blocks outside the while loop did you enable indexing on the tunnel that gets created at the border of the while loop? If you don't you'll get at best the last data point. See attached update.
As for the serial timeout, that's set with a VISA Property node.
Message 7 of 17
(3,638 Views)
Timeout is set in the very fist block before starting the while loop.
Matthew Fitzsimons
Message 8 of 17
(3,634 Views)
thanks guys, i will do these changes now and let you know i get on!
all the best
Eric
Message 9 of 17
(3,626 Views)
ok lads,
i changed the timeout, but it didnt make much of a difference, however the value of N in the for loop did, i put this down to 200, will this effect my results been sent to excel?
im still not getting any data sent out though, i put on indexing, on the for loop and the while loop.
whats going on, why doesnt the data send out? do i need to assign the measurement block with more signals...?
regards
Message 10 of 17
(3,614 Views)
