sampling time in labview of usb connection from tektronix oscilloscope
hello, im using a usb connection to transfer the data to the PC from a tektronix 2024b oscilloscope.
2500 points come in each time from the scope, the sampling independent of the scope time setting.
When i run the program at full tilt, ie, no plotting, in labview 8.5, i get about 1 set of 2500 points each second.
Ideally i need around 100 samples of the 2500 points in one second.
I would like to know what is the rate limitation.
Its probably the oscilloscope i guess, but cant find the usb speed in their manual.
Ill post the file Im using
http://www.engr.uconn.edu/~jmacione/temp/Copy%20of%20trigger_acquire3.vi
thanks
Message Edited by jimmyinCT on 01-20-2009 09:58 AM
(2,903 Views)
This most probably has to do with a limitation of the oscilloscope. I would contact tektronix to check what the maximum number of points per second that can be sent over the USB port is.
Vivek Nath
Machine Vision
(2,877 Views)
