sampling rate problem labview pda
hi, im testing my pda labview system to see what speeds i can actually acquire at. im using a signal generator as an analogue input generating a sin wave at 2khz and around 2V amplitude. im using finite acquisiton to acquire between 50-200 samples using the ai finite acquire pda example
when i acquire at 5khz [well above nyquist] i get rubbish data hinting that the system can actually reach 5khz, yet when i increase the sampling rate to 10, 15, 20 and 200khz the data improves and actually looks like a sin wave. does this mean that its only achieveing a certain percentage of the specified sampling rate each time?
yet when i input a square wave the representations seems correct - ie start to foul up when i approach the nyquist limit.
ive stuck a zip file of photos of the pda acquiring at the different rates.
thanks alot
andy
(2,979 Views)
What version of the PDA Module are you using and what DAQ are you using?
(2,975 Views)
labview 8.2 +pda module, daq mx base 2.2 and a cf-6004 with ipaq 5550 and expansion sleeve
cheers
(2,964 Views)
Hey Lav
Here is an tutorial on sampling and Nyquist
http://zone.ni.com/devzone/cda/tut/p/id/3000
I think the data you are collecting is expected.  You are only collecting 2.5 samples/ Cycle not enough to reconstruct your waveform.
I think you will find your PDA is working as well as a PC Daq when it comes to sampling the signal you are trying to acquire.
(2,958 Views)
