sample rate
I have a question about the sample rate: i have acquire 4 channels and i use the vi "acquire waveforms.vi". For example if I set the sample rate to 50 ksample/s , the daq acquire each channel with 50 ksample/s or 50k/4 ? I use a DAQ with a max sample rate of 200 ksample/s.
Giovanni77
Message Edited by yettaboom on 01-13-2006 02:23 PM
(3,366 Views)
I'm sure you have a question but it would be nice if you actually asked itSmiley Very Happy.
(3,353 Views)
Perhaps the following Data Acquisition Sampling Terminology here may help you understand your problem
Specifically
"Sample/Sampling rate (scan rate)
The rate at which one sample per channel is acquired; the rate at which the sample (scan) clock is set. Note that the maximum sampling rate specification for our E Series data acquisition boards refers to the maximum rate at which a single channel can be acquired. For example, the PCI-6071E is capable of a 1.25 MS/s sampling rate. This may consist of 1.25 MS/s on one channel or 250 kS/s on five channels.
Links used: -
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/dbe7ac32661bcf9b86256ac000682154?OpenDocument
(3,341 Views)
You would acquire each channel at 50 ksamples/sec.
(3,326 Views)
