sample frequency in digital IIR filter
I have a waveform (1D array of SGL) that I need to lowpass filter. When I use the Butterworth VI, I can set the sample frequency with which to sample & vary the cutoff freuqency & observe the low-pass filtering results.
When I use the digital IIR filter VI, it gves me the error :
Analysis:  The following conditions must be met:  0 < f_low <= f_high <= fs/2.
How does it know what the sampling frequency is ?
IS there a setting in the IIR filter specifications cluster that will help ?
ak
(2,933 Views)
cig438,
Can you post a small section of your code that demonstrates the problem?
Chris C
(2,915 Views)
