same plot propertys for n plots
I would liek to keep the same plot propertys (color, style, line style, etc..) for n amount of plots that i will be graphing on an xy graph. how would i go about doing this?
(2,902 Views)
Create a for loop with a property node linked to the XY graph. In the loop feed the active plot property with the indexes of the different plots you want to set the properties of and then wire up the rest of the plot properties...
If you want *all* the plots identical just wire the loop index to the active plot property and set the loop to run as many times as there are plots. As shown on the attached picture (making plots 0,1,2,3 & 4 identical in line style and color).
(2,902 Views)
Thank you very much. I was kinda on that trail without the ActPlot. Got me back on track.
Mark
(2,902 Views)
