03-19-2007 02:44 AM
03-19-2007 05:31 AM
03-19-2007 05:46 AM
03-19-2007 11:52 AM
Your sceme is fine. The error cluster is a generic container to pass any error that can occur from one function to the next. Normally, if a function has it's Error In terminal connected and an error is passed in from a previous function, that function will not do naything except pass the error through so it can be handeled in you code.
Since your running on serial, just "serialize" your initialization functions using the error cluster to set the order. This way only one will be running at a time. It doesn't matter what order.
Ed
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
