running multiple tabs simultaneously
I'm trying to monitor multiple sensors simultaneously in groups of four by four, each gruop of four being situated in a diffrent tab. The problem is that I can't run simultaneously all tabs to monitor the entire group of sensors. I have a loop instance (while) for each tab and I have to close the running oane each time I want to shift to another tab. Is there a solution for my problem?
(2,800 Views)
Hi Alin,
run the 4 while loops in parallel...
Displaying values using tabs is not related to running code in your block diagram. Tabs are (mainly) used for separating groups of controls/indicators in the front panel...
(2,792 Views)
