running a labview installer without installing drivers
Ouch. I have to install multiple LabView programs onto the same machine and they were all compiled with different versions. I don't have the luxury of rebuilding them. When I try installing some of them, the program won't let me install because newer drivers are already installed on the machine. Is there a way of running an installer to install the program without installing the drivers?
(2,565 Views)
Accepted by topic author Steve_Block
The folder where the installer was placed into should have a bunch of folder in the "bin" folder all starting with "p". These contain the various installers that are run. The actual installer for your executable should be in there somewhere, so you could try running it directly.
(2,560 Views)
Thanks. I cannot try it at the moment, but for now will accept it as a viable solution.
(2,553 Views)
